Community Member
install CUE license files with FTP help
Can someone help me out  with the install of cue license files with ftp.
I am a little bit lost.
I have the license files of cue, ( cue-vm-license_12mbx_ccm_7.0.6)
But not sure what i'm doing wrong, using filezilla looks so complicated.
Does someone know how to use it with  ftp client.
I know the instructions how to session into the AIM module, already configured my service engine.
But i''m stuck with the ftp part.
I gave my router statically ip adress 10.10.210.17/24 my local laptop has statically ip of 10.10.210.15/24
I am able to ping and backwards reachability is fine.
hi monasir81
CUE-SM#license install ftp://username:passwd@/path/license_file.lic
Optionally if FTP server is setup for Anonymous user, then following command can be used:
CUE-SM#license install ftp:///path/license_file.lic
and you sure the correctly instalation when apper this
Application will evaluate this change upon next reload
1/1 licenses were successfully installed
0/1 licenses were existing licenses
0/1 licenses were failed to install
i use 3cdaemon ftp server
best regards
Community Member
Have you already tested with any other PC/laptop you can reach and download from your FTP server?
If the FTP connection is OK, then follow this procedure on the cue module:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/install/upglic.html#wp1140481
BR,
Peter
BR, Peter
2602
