Install Memory MCS 7825
There is some guidance of the motherboard of Cisco MCS 7825-H2 server? I need to install new memory and I would like to know the procedures and see the image of the motherboard.
How many DIMM memory modules have the Cisco MCS 7825-H2?
Hall of Fame Super Red
Hi Matthew,
The 7825H2 has 4 DIMM slots of which 2 have installed DIMM modules. There is an image
here (with zoom) that will give a fairly close example (it's not an H2) but you will be
able to see the slots to the bottom left on the image;
http://www.ebay.com/itm/Cisco-MCS-7825H-2-2-ECS1-51MB-Ram-2-26GHZ-Processor-Media-Convergence-Server-lgg-/230767771845?pt=COMP_EN_Servers&hash=item35bad4c0c5
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Thanks Rob.
I have used the commands: show memory count, this command display the total number of physical modules available on the system.
302
