Community Member
Install of Unity Connection 2.x
All, I am about to install Unity Connection 2.x on a new server. It appears that the new server has a pre-installed package on it, but it looks like its CUCM 6.1.1, and not Unity Connection. It did come with a Unity Connection DVD, so my question is am I supposed to boot to the DVD or do I need to go through the pre-install process? I put the DVD in, and it told me that there was already a version of Communications Manager on there. Im a little confused because I would think that CUCM wouldnt be on this server and it wouldnt look for it. Anyone know how I should proceed on this?
Community Member
Re: Install of Unity Connection 2.x
Ok, its the DVD. CUCM comes pre-installed and I must go to the DVD. Sorry for the dumb quesiton.
Community Member
You will need to reimage the server with the DVDs that came with unity connection. You will be prompted for CCM or Unity connection.
