Installaing Unified Communications Manager 6.0.1 and Unity Connection 2.0
Hi Team,
I am trying to install Cisco Unified Communications Manager 6.0.1 Business Edition and Cisco Unity Connection 2.0 as co-resident applications on the MCS-7825H3 Servers.
When I start the installation I get 2 options to select between Unified Communications Manager and the Cisco Unity Connection, however when I complete the installation of one of these applications and want to install the second one the existing one gets overwritten thereby the server has either Cisco Unity Connection or Cisco Unified Communications Manager 6.0.
Any help in this regard is highly appreciated.
Sriharshaa Prabhakar
1 ACCEPTED SOLUTION
Re: Installaing Unified Communications Manager 6.0.1 and Unity C
the problem is most probably you do not have enough memory or CPU to support both apps, the install disks check the server capabilities and if does not detect the requirements for both apps to run at the same time you only get the option to install 1.
if you DO have the resources then you should get the 3 options
CUCM
CUC
CUCM and CUC
you would need AT LEAST 4 GIGs in RAM, that's why we provide some servers specifically for BE
7828 is a powered up 7825 for the sole purpose of providing the necessary resources to run the apps without any CPU or memory issues and some extra resources.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
CUCM
CUC
CUCM and CUC
javalenc
java
Hi Jaime,
Thanks a lot for this information
140
