Installation CUCM 7 - "No driver found"
ricardorojas123
I insert the DVD in the tray of the server and I restart the server, so it boots from the DVD. The wizard of the installation of CIsco Unified Communication is showed. The question of the Wizard or Initial Configuration are showed, these question are as following:
Choose Lenguage, Keyboard Type and Installation Method.
In the Installation Method, I select Local CDROM and OK, but the next message is showed:
No driver found
Unable to find any devices of the type needed for this installarion type.
Would you like to manually select your driver or use a driver disk?
Because of this, I have not made ​​progress in the installation.
you could give me any suggestions?
(I am using a UCSc210m2 Server)
Aaron Harrison
You can't isntall CUCM on a C-series. You have to install VMware ESXi and then install CUCM into a virtual machine.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
William Bell
When you say you reboot the server are you talking about the physical host or a virtual machine? On the UCS platform, the idea is that you are running a hypervisor (ESXi 4.1+) and your CUCM OS/Application is being installed in a virtual machine running on that UCS compute platform.
See here for a VOD covering the UC on UCS solution:
https://supportforums.cisco.com/videos/2620
See this for UC virtualization Wiki:
http://docwiki.cisco.com/wiki/Unified_Communications_in_a_Virtualized_Environment
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
