Community Member
Installation of CME 8.0 with Cisco Unity express 8.0
I want to install Cisco CallManager express with CUE for VM .
is anyone can tell me the process of installing the same. i got lots of contents in Google . but hope if someone from community help me providing the step-by step installtion process .
Your help would be really appreciated . Thanks a Ton .
K.S.
1 REPLY
Blue
Below is the good document by Cisco on CME CUE integration
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/integration/unity_exp/configuration/guide/cue_cme1.html
regards
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
153
