Installation of unity
prabhusworld
To install unity what are the requirements except Unity application, and Cisco Server. Any Hardware Called Voice Cards are required or not.
6 Replies 6
lpezj
Level 7
Level 7
If you are going to integrate Unity with CallManager, you won't need any Voice Cards.
These voice cards are used only to communicate Unity with TDM PBXs (Avaya, Nortel, Alcatel,...).
Hope this helps,
Juan Luis
Dear Juan,
Thanks i understood. what is Cisco uOne Port, what is that? Is it Software or Hardware, what it is the application of that?
Thanks & Regards
Prabhu
Prabhu,
uOne is an old unify messaging system from Cisco. But that system is out of sdervice for some years.
Hope this helps,
Juan Luis
(Rate helpful posts ;-))
Dear IPezj,
Are you having any steps or procedure to intergate Unity and Call manager.
Thanks & Regards
Prabhu
Without knowing your specific versions...
here is some good documentation:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a008070e4b0.html
Dear Sir,
I am having Cisco call manager and EPBAX which will support IP. with this can i interface both or i required any voice cards.
Thanks & Regards
Prabhu
