Installation problem 7.1.2 MCS 7825
i have a problem during installation of CUCM 7.1.2 on MCS 7825-H3-IPC1.
After skipping the "media check cdrom" and running the installer, the system doesn't find any hard drives. The error here below:
Error: not enough physical disk      [ 0 out of 2 present ]
A RAID 1 array has been createdI before and the status is optimal.
I have tried to disable the controller SATA and the installation has finished without any problems, but the system fail in "kernel panic" because the new root isn't correctly. ( after reboot )
Anyone has the same problem ?
Thanks a lot.
Everyone's tags (4)
286
