installing call manager 4.2.1
I am just having a bit of problem when installing the call manager 4.2.1
after I put in the disk and entering all the password to install the call manager, it pop up the following error message:
iuRun Command
CreateProcess: Error:2: The system cannot find file specified
the OS version is 2000.4.3a and 2000.4.3aSR7
any idea?
Kind regards
Rachel
1 REPLY
Silver
Re: installing call manager 4.2.1
The system cannot find the file specified. This error occurs when the file named in the command does not exist in the current directory or search path specified. Or the filename was entered incorrectly. Retry using the correct filename.
167
