Installing CUCM 8.5 for 300 Users - Which Hardware?
Good day,
I have been tasked to deploy Cisco Unified Communications Manager 8.5 for around 300 Users. I am a bit stuck on the choice of which Hardware Platform should CUCM 8.5 runs on for those 300 Users.
Could you please suggest to me if I should go for an MCS Server Platform or a UCS Platform for that kind of deployment?
At the same time, I should put in mind having Cisco Unity Connection 8.5 installed as well to serves for Voice Mails for all those 300 Users. Which Hardware platform should I go for that as well?
Your expert advices will be much appreciated.
Warm regards,
J. Kabundi.
1 ACCEPTED SOLUTION
Not sure about prices but for that amount of users a CUCMBE3K would be enough.
Release Notes for Cisco Unified Communications  Manager Business Edition 3000, Release 8.6(1)
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucmbe3k/8_6_1/release_notes/3krel_notes861.html
If you want to go a little bigger if they plan to expand maybe a CUCMBE 5K.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Bronze
Good recommendation
note the url below though and specifically the supported phones just in case youre looking (or rather the customer is) for a feature or type of phone and you then realize it isnt supported.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucmbe3k/compat/3kcompmtx.html
Good day,
Thanks all for your advices and assistance.
Much appreciated. I will investigate more on the CUCMBE 3K and 5K so that I can choose which ones will best fit for future scalability as well.
Warm regards,
J. Kabundi.
320
