07-30-2008 01:32 AM - edited 03-15-2019 12:17 PM
I recently uploaded a device pack on CUCM 6 to add a new phone type , I `ve done this before on 4.x and 5.x . On 4.x when you install the pack, you can instruct CUCM to install the new phone loads in to TFTP only but do not update the device defaults so you can manually control when you wish to update the phones, this was also the case on 5.x though it was not as obvious however on 6.x this seems to have disappeared. We have installed a device pack on two different CUCM 6.0 and on both occasions it updated all the phone loads in the device defaults without the option - has the process changed now or did I miss something ?
thanks
Solved! Go to Solution.
07-30-2008 05:19 AM
6.x won't ask you for that, it will change firmware of device defaults if included in the DevPack
java
if this helps, please rate
07-30-2008 05:19 AM
java
07-30-2008 06:01 AM
So it is working as per , any idea why was it changed?
07-30-2008 06:12 AM
not really =(
probably has to do with the fact that now we're trying to lock down everything and give less options to avoid failures
java
