Insufficient Licenses (Basic (9.x))
hodgey1987
Hi All,
We're having a few issues with cucm where it's showing we have insufficient licenses (image attached) we only have the 7821 and 3905 phones on site.
It's the first time we have come across this issue in 2 years, whats the best way to troubleshoot this sort of issue? We've tried removing some of the phones completely but that hasnt worked either.
9 Replies 9
Manish Gogna
The 7821 IP phones will require the Basic license, how many of those do you have in your setup?
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7800-series/data-sheet-c78-729488.pdf
Manish
any change u did in CUCM like added Device pack ,upgrading phone firmware.
regds,
aman
Thanks both for contacting me, we have 108 phones logged in at the moment of the 7821 model.
The number of Basic licenses that are installed are less than your requirement, so it seems that the 7821's are borrowing the higher licenses at the moment while generating this warning for the Basic licenses. Did you notice this warning today or has it been there for a while?
Manish
It seems that you have 112 BASIC phones as of now.
You have purchased 80 BASIC licneses and 30 were borrowed from CUWL standard.After the same were finished , 2 more  connected.
So, again 2 licneses were borrowed from Enhanced.
regds,
aman
Thanks for all your help, I'm still seeing the same issues however only 1 license now. Is there anyway i can troubleshoot this through logs? To see the last phone that was connected to the network?
we can go through  diagnostic  logs provided they were configured when phone was connected and give some info related to your issue.Even though I have never tried this.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/elmuserguide/9_1_1/CUCM_BK_EDEFFAEB_00_enterprise-license-manager-user-91/CUCM_BK_EDEFFAEB_00_enterprise-license-manager-user-91_chapter_0100.pdf
I think u would be remembering the MAC address of IP phone connected in network.
regds,
aman
Thanks Aman, just checking through the logs now found the following:
{"status":"Insufficient Licenses","installed":"80","allocated":"81","type":"Basic","seqNumber":"2120","version":"9.0","productType":"Unified CM","displayVersion":"9.x","free":"-1","licenseTag":"UCM_Basic","productTag":"UCM","borrowed":"28","displayStr":"Basic (9.x) - Unified CM","statusLevel":"ERROR","objectId":"ba03b97a-f0a3-4b15-a1fb-2fdfa9b3a0d5","loanedOut":"0","required":"109"}
2014-09-26 14:55:08,455 DEBUG [http-bio-443-exec-85]
Is this objectId referenced against a mac address?
I was just referring the link which has some SQL queries related to ELM
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117600-technote-cucm-00.html
I found the nearest  query
 run sql select pkid from enduser where userid = 'jbardy'
but it works when we have userID associated.
Just play with these queries if it helps.
regds,
aman
