Integrate AD (with Multiple OUs) with CUCM 9.1.2
Hi Experts,
I have a unique question.
We need to integrate AD and CUCM 9.1.2 and sync the DBs, but the we need to sync multiple OU's with in the AD.
For example Head Office has its own OU and all the branches has their own OU's as well.
Will this be possible and how to I filter ?
Best Regards and Thank you in advance.
Voice CCIE #37771
1 ACCEPTED SOLUTION
yes its possible by creating
yes its possible by creating multiple directory sync agreements. You will be limited up to 5 directory sync agreements though. Another way to do it from the AD side is for the account that is being used for integration, provide read rights to only the OUs that you need to sync into CUCM. For, authentication, you the search base should be the root of your forest.
Please rate useful posts.
Fantastic and thank you.
Voice CCIE #37771
50
