Integrate Callmanager 4.2 with harris 20-20
Dear All,
I have call manager 4.2 and we have integration with Harris pbx 20-20 through PRI E1 using Etsi signal and I tried all "ISDN switch type on voice gateway as net5 ,4ess..." I debugged q931 when i tried all types of isdn switch type but all signal generate "bad frame" taking into consideration that we are using two Multiplexers TC8518 T1/E1
your fast reply is highly appreciated
Green
Re: Integrate Callmanager 4.2 with harris 20-20
MGCP or H.323?
Check network side/clock source
Normally should be the opposite, once emulates the PSTN switch.
mgcp and I already configured the call manager as user side and clock source internal and this opposite on PBX
thanks for you.
I finished the integration using ETSI signaling but now I need to add prefix behind the calling name i.e when i make call from call manager to PBX the presented name is Hany I need to add "TB3" behind the name regardless the name
Best Regards;
Hany
Hall of Fame Super Gold
It is not possible to manipulate names in Cisco IOS.
You would need a custom TCL/IVR script and using H.323 for this.
If you're interested in having the script developed for a reasonable fee, contact me at the address present in my profile.
411
