Community Member
Integrate CUCM 6.0 with CCME
We have two international locations.
At one location (location 1) we have CUCM 6.0 & at the other location (location 2)we have CCME on 2800 router.Both locations are connected via 512K international MPLS link.
Requirements:
We want users behind CCME to use local PSTN & when the users want to call to location 2 extensions they use the international MPLS link & visa-versa.
Queries:
1.How do we integrate the CCME with CUCM.What are the required parameters that need to be configured on CCME & CCM.
Thanks.
Rgds./Sack
Green
Re: Integrate CUCM 6.0 with CCME
Hi Sack,
You can integrate it via SIP or via H323 because of the international link i would go for H.323.
You need to configure in cme dial-peers pointing to cucm and in cucm route oatterns and add an h.323 gw
if you browse our site there is some documents for this integration.
Community Member
Hi Gonzalo,
Thanks for your prompt response.
Can you share some documents if you have to do the same.
Rgds./Sack
119
