integrating ccme 4.0 to ccm 4.2
how we can create a dial plan pointing from ccme to ccm , how the digit discarding need to be discard before i send the digit to ccm.
waiting for your valubale reply.
Re: integrating ccme 4.0 to ccm 4.2
All you need to do is to create a voip dial-peer pointing to the GW that is handling the incoming calls to the CCM, on that GW you should have an incoming dial-peer and an outgoing dial-peer that points to the CCM. Then on CCM you should already have the significant digits on the incoming calls part of the GW config page in the CCMAdmin.
That is all, is actually pretty simple as you can see.
//Jorge
that completely depends on what you're going to dial and how many digits your dial plan is.
if you create CME as an H323 GW you can configure the inbound digits to X (X is the number of digits your DNs have)
you can configure a translation-rule to strip the digits before sending the call to CUCM
both would do the same, but CCM config is easier
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hall of Fame Super Red
Hi Sunny,
Just thought I would add this;
This doc shows the integration steps;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmetrans.html#wp1121584
Hope this helps!
Rob
102
