Integrating CME 8.6 with CUCM
ivan aguilar
Hi!
I am trying to integrate a CME 8.6 with CUCM via MacroLan, i introduce this commands in router to do this:
dial-peer voice 1234 voip
preference 1
destination-pattern 1...
session target ipv4: <IP del CUCM>
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Interface gigaethernet0/0.10
h323-gateway voip interface
h323-gateway voip bind srcaddr <ip del CME>
When I place a call to extension in CUCM , call goes in dial-peer 1234 but drop calls.
Do I need to modify or add anything else or is a Macrolan problem, so Operator must to do it?
regards!!
2 Accepted Solutions
This should E1-ISDN call not IP call between systems.
Where are you calling from to? Please post you entire config.
Chris
On CME you need to have a voip dial-peer that points to the IP address of the CUCM, and matches the destination pattern of CUCM DNs.
On CUCM you need to ensure the H323 GW is configured with proper CSS which can route the call to the partition of the phone DN and the significant digits on the GW configuration is set properly.
That's about it.
Chris
15 Replies 15
nikshah
Hi Ivan
see the region relationship between the the ip phone and the gateway(trunk) going to the CME, as you have set it as g711 on the dial-peer.
get me a set of ccm traces along with calling party called party information going towards to the CME with detailed traces and enable gateway trace.
Hope this helps
Niket
Finally I resolved the connectivity problem, actually i ping from CME to CUCM, but stills can not place call between the two headquarters.
step 1, I create in my side one dial-peer (see in the last post) and a h323-gateway voip interface
step 2, in the CUCM I have created one route pattern to my new extension.
Do I must to create another dial-peer o h323 in the CUCM gateway?, which should be the step 3?
Thanks!
You need to configure the CME as an H323 GW using the IP to which you're binding the signaling.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
What is the GW configured like in CUCM, how many sig digits did you select and does the calling search space have access to partition assigned to the DN you are calling?
Is the GW showing up in CUCM with the IP address and registration UNKNOWN?
Chris
Actually from CUCM still can not phone my extension in the CME, so need to add anything else, or a h323 gateway o i dont know.
regards.
Can you post "sh run" and "debug voice dialpeeer"?
Chris
So far what do you have configured on both sides???
java
java
192.168.6.9 CME
192.168.100.2 CUCM
192.168.100.1 GW of CUCM
CME
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.6.9 255.255.255.0
h323-gateway voip bind srcaddr 192.168.6.9
session target ipv4:192.168.100.2
codec g711ulaw
no vad
CUCM
a route pattern- RL-RG to my extension in CME 4[01]XX
GW
  ip address 192.168.100.1 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 192.168.100.1
session target ipv4:192.168.6.9
codec g711ulaw
no vad
With these commans does not run, any idea if need to add anything else??
Regards!
one change, in cucm dial-peer voice 1234 the destinattion-pattern is 4...
still place a call by pstn and drop the call
Calling Party Number i = 0x0081, '93XXXXXX'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '4110'
Jul 19 15:53:07.122: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8530
        Channel ID i = 0xA9839E
                Exclusive, Channel 30
Jul 19 15:53:07.498: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8530
thanks!!
Chris
Vi
I am making a test from CUCM to CME and fails because route the call by the PSTN
I have added a H323 Gw in the CUCM with the IP 192.168.6.9 (CME IP), but when I try to place a call from a CME extension to a CUCM extension, drop the call.
What I need to add to my configuration in order to run this integration???
Thanks!!
That's about it.
Chris
Finally it was resolved, the problem was with the CSS_inbound of the Gw H323.
After change it, already is working properly.
Thanks, and regards!!!
