integrating cme with ccm
hi, i am integrating a cme v 7.0 with a ccm 4.1, using h323 protocol, in the cme, i created a dial-peer voip pointing to the ccm's ip add, and in the ccm, y create a gateway h323, pointing to the cme ip add, and then the route pattern with the specific gateway.
the problem is, when an cme ip phone call to an ccm extension, it rings, the call establishes but after 4 sec the call is disconnected.
if the call is from the ccm phone to the cme phone, the call works fine,
the cause is temporary failure (41),
do you know why does this cause happen?
Hall of Fame Super Silver
Re: integrating cme with ccm
Instead of H323 GW configure intercluster trunk on the CM side.
Chris
hi, i tried but the calls comming from the cme to the ccm fail. the only calls that work is from the ccm to cme.
the other thing i reviewed was, the region, for using the 729, and the location, bw voice = unlimited, this was applied to the gw config in the ccm.
Hi Giovanni,
Try these things, they may help:
dial-peer voice x voip
no voice-class codec
codec g711u
no vad
incoming called-number .
interface fa0/0
h323-gateway voip bind src-address 1.1.1.1
On CCM:
In the H323 gateway page:
Check 'Enable Inbound Fast Start'
Uncheck 'Wait for Far-End H245 TCS'
Reset gateway
hth,
nick
Hall of Fame Super Gold
do you have "codec g711u" under the DP for CCM? Which setting do you have on CCM for the CME GW ?
173
