Community Member
Integrating fax machine into call manager express 4.0
I need help (Configuration guide) to integrate a fax machine to Cisco call manager express 4.0 or later connected via an FXS Card to the router.
Currently I have a dedicated line (number) from the E1 channel for the Fax machine.
How do I go about the configuration
Re: Integrating fax machine into call manager express 4.0
plug the FXS card into the same chassis as the E1 interface. Point a specific dial peer for the fax number to the FXS port. Calls to this number will be sent directly to the FXS port.
Something like this should work ...Assume the inwards number range is 55551000-1999
The PRI card is in WIC slot 0
The FXS card is in WIC slot 1
The fax number is 55551999
network-clock-participate wic 0
network-clock-select 1 e1 0/0/0 <--- very important for faxing !!!!
voice-port 0/0/0:15
cptone GB
voice-port 0/1/0
description - fxs to fax
cptone GB
compand-type a-law <---ensures same companding on voice ports so DSP is dropped after connection (pure TDM switching)
dial-peer voice 1 pots
description - dummy dial peer to enable Direct inward dial
incoming called-number .
direct-inward-dial
port 0/0/0
dial-peer voice 2 pots
description - calls to fax machine
destination-pattern 55551999
port 0/1/0
dial-peer voice 3 pots
description - outwards calls to PRI - users dial 0 for outside line
destination-pattern 0T
port 0/0/0:15
Community Member
Hi Paul:
Can you elaborate on how this works? Why do you have to enable DID?
direct-inward-dial
port 0/0/0
Diego
There was a slight type on the config - it should read like this :
direct-inward-dial
port 0/0/0:15 <---- PRI D channel
ISDN was designed to allow single stage dialing , meaning that a caller would dia a number, and the entire called number is passed to the called party and it should ring at this phone without any operator intervention.
To allow the voice gateway router to take the called number (otherwise known as the DNIS) from the Q931 setup message and match it on other dial peers, you need the POTS dial peer command 'direct-inward-dial'. With this command configured on a POTS dial peer, when a call comes in through the particular voice port , IOS will work through the list of dial peers. It will come to dial peer 1 , and since it has 'incoming called-number .', and the call came in on port 0/0/0:15, it will match on this dial peer. The DID command will then take the DNIS and this can be matched on other VOIP or POTS dial peers. Without the DID command, the caller woul just hear a secondary dial tone and they would need to enter the called number again as DTMF tones.
Hall of Fame Super Gold
Actually, no "port" command is not necessary for the incoming pots DP dedicated to direct-inward-dial.
Community Member
I think this explains what is happening to me at the moment. I have a PRI PSTN trunk where I can see the DNIS info on the Q931 messages but yet I can't get the incoming calls to match any DNs. The callers get a dial-tone and then a fast-busy. Will creating this dummy dial-peer with the direct-inward-dial command fix this system system-wide or do I need to use it somewhere else?
Diego
You configure as above and that's it.
Had you reported the symptom of getting dialtone in the other thread, I could have suggested that before.
Community Member
Yes, you are right I should have mentioned it. I didn't realize that was such an important clue at the time.
Rgds,
Diego
Community Member
Hi Paul,
I am trying the following
dial-peer voice 70 pots
direct-inward-dial
port 0/3/0:23
When I enter this all incoming calls get the dreaded three increasing pitch tones. Without the command I receive the secondary dial-tone that you mentioned. Any ideas?
Diego
Community Member
Actually, nevermind. I got it. Seems I need that dial-peer AND a translation profile on my PRI voiceport. Looks like I am good to go.
Diego
the thre tones suggest the router is looking at the incoming DNIS , failing to match on a dial peer and sending a clearing code of 1 - invalid/unassigned number.
Run 'debug isdn q931' and make a test call. Log this, and paste you current config here so we can check.
Community Member
I got it working but maybe you could be so kind as to clear something up for me. I decided that it would be best to setup a simple translation scheme that trans DIDs to extension numbers on inbound calls and sends out the main office phone number as the calling number when any extension dials the PSTN. Something like this:
Inbound
4085551111 -> 201 (main PSTN to reception)
4085552222 -> 202
4085553333 -> 203
Outbound
201 -> 4085551111
202 -> 4085551111
203 -> 4085551111
What I did to accomplish this was to add a "incoming called" translation profile to my PRI (voice-port 0/3/0:23) and then an "outbound calling" to each of my dial-peer that match outbound calls.
My question is why did I have to apply the inbound to a voice-port but yet the outbound to the dial-peer? I tried to add the outgoing to the voice-port but it did not work. Why the difference?
Diego
432
