Integrating H.323 gateways with CUCM 8.5
Hello  guys!
       Im in the phase of integrating a CUCM 8.5 with a H323 Voice Gateway (CISCO2921-V/K9). The Cisco 2921 will be connected through interface Gi0/1 to the CUCM 8.5 and through interface Gi0/0 to the PSTN Service Provider. There will be only this voice gateway for incoming and outgoing calls from and to the PSTN. I have already configured the Device H323 Gateway in the CUCM and a couple of Route Patterns fro local calls. My questions are the following:
1. Which are the next steps necessary for the integration?   Since there is only one H323 gateway, do I need to configure a Route Group and Route List.
2. When I tried to configured the Route group in the CUCM 8.5, there is no device available to be included even thou I already configured the H323 gateway in the Devices for the CUCM 8.5
Thanks a lot guys, Im new to VoIP so Im in the learning process.
2 ACCEPTED SOLUTIONS
Re: Integrating H.323 gateways with CUCM 8.5
Nephtali,
Here you go with answers..
Ans : Indeed not required if it's going to be the only gateway.
Ans : Are you able to make/receive calls through that H.323 gateway ? Could you post the running config of gateway router ?
or please confirm if you have this command ( h323-gateway voip bind srcaddr ip_address ) configured under interface Gi0/0 ?
Refer http://docwiki.cisco.com/wiki/Cisco_IOS_Voice_Troubleshooting_and_Monitoring_--_H.323_Gateway_Troubleshooting#Binding_the_H.323_Signaling_to_a_Specific_IP_Address
GP.
Pls rate helpful posts by clicking on stars below the post !!
integerating CUCM with h323 gateway:
     - add the gateway on the cucm
     - define route pattern and forward them to the configured gateway
     - on h323 gateway just configure the dial-peers of required route patterns which were defined in CUCM earlier.
     - define a dial-peer to route incoming calls to CUCM
     test outgoing and incoming calls.
     you can can furthur restrict / allow calling priviligies per users by configure Class of Control via partitions and CSS.
Nephtali,
GP.
Thanks for the help. I think this is the way to go in this case. Thanks again.
Thanks for the reply and information. Which is the command to generate a call for the Voice gateway? Thanks again.
VIP Super Bronze
Nephtali,
Just for furture purposes, the reason why you do not see a gateway to assign to the Route Group is beacuse you have already assigned the gateway to the Route Pattern. So if you want to assign a gateway to a Route group, then you cant assign it to a route pattern
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Excellent! Thanks a lot for the information.
1591
