Integrating to AD after using CM direcotry database
I have a customer running CM7 that wants to integrate into thier AD now.  I dont want to delete any users and do a clean integration so if the usernames are the same in AD as they are currently in the CM system will this just "update" the current user?
1 REPLY
Silver
Re: Integrating to AD after using CM direcotry database
Edward,
From the SRND 7.x, "Synchronization Mechanis" section:
"When synchronization is enabled for the first time  on a Unified CM publisher server, user accounts that exist in the  corporate directory are imported into the Unified CM database. Then  either existing Unified CM end-user accounts are activated and data is  updated, or a new end-user account is created ..."
https://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/directry.html#wp1045284
Hope it helps.
130
