Integration of Polycom PathNavigator and CUCM 6.0
We are looking to Integrate Cisco CUCM 6.0 (callmanager) with PathNavigator, Calls between IP Phones and Video Endpoint works only on one way, Cisco IP Phones can dial Video endpoints without problems, Video Endpoint can not dial IP Phones.
Here is what I have configured on CUCM.
1. I have PathNavigator registered as GK
2. Trunk configured as GK controlled (Type Gateway)
3. The Polycom Endpoints as H.323 Phones controlled by GK.
4. Route pattern (7XXX) using the Trunk to PathNavigator
As result of the above configuration on CUCM I can see two new endpoints GW RASAgregator and GW trunk. Also On the Services I can see the 1# prefix pointing to the Gateway (CUCM).
If I dial from IP Phone to he Video Endpoint works.
If Video Endpoint dial to IP Phone FAIL.
Im dialling with "1#IPPhone extension" (1#8200) or 98200.
None of them works,.
Bronze
Re: Integration of Polycom PathNavigator and CUCM 6.0
Need some more details. Can you post the following from the GK:
show version
show run
show gatekeeper end
show gatekeeper gw
The Gatekeeper is a Polycom Path Navigator, so I can not give to you the show commands you are asking..
But, You may have an answer for the next situation...
Becauase Path Navigator and CUCM doesn't work well (At least I can not make them work) I Configured a Cisco GK and CUCM and both work very well But I need to Know how to make the GK work with Polycom V2IU 5300-E. I need to know how to configure the V2IU to forward incomming calls to the Cisco GK and how to make the Video Endpoint able to dial (IP) out of my network trough the V2IU.
Any help will be appreciated.
I'm trying a similar thing.
I have a CUCM 6.x  IOS GK trying to pass a call to a remote PathNavigator GK
So far I've registered the trunks but had no sucess at a call level.
Advise would be appricated.
Nick
No news yet, I had that project on hold for a while. Now Im taking
it back. Did you made any progress on integrati
ng PathNavigator with Cisco GK?
If so, could you please share the configs on PathNav and Cisco GK?
REgards.
491
