Intelligent speed search
I am looking for a 3rd party solution for the following
rather than having to press buttons for the in built directory and then type in a name search, which is rather a laborious process.
we have a need for an intelligent search for the following scenario..
customer would like to call a colleague called Martin. takes the phone off hook and presses    62786     (6(m) 2(a) 7(r) 8(t) 4(i) 6(n))
The software will intelligently work out from it's database of numbers, the closest matches for those key presses, the user will then be presented with the names.
Apparently this used to be a feature in the old analogue systems. does anyone know if there is an offering for Cisco?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Some 3rd party corporate apps
Some 3rd party corporate apps, such as syn-apps provide what they call predictive search that would do exactly what you are describing. This is not there natively in CUCM so you will need to get 3rd party corporate directory or develop your own.
Chris
Chris
Thanks Chris, just checked
Thanks Chris, just checked the website, looks exactly what I need
25
