Inter-cluster Trunk Compatibility
I have to (2) CCM 4.2 clusters that needs to be upgraded to CUCM 7.1 and want to upgrade (1) cluster at a time.  If I upgrade (1) cluster to 7.1 and left the other cluster on 4.2, will the inter-cluster trunk still work after upgrade???
2 ACCEPTED SOLUTIONS
Re: Inter-cluster Trunk Compatibility
I believe so, i did the exact same thing a year or so ago and had no problems.
Nelson,
Yes, ICT will work just fine. I have recently (1 month ago) done this at
two separate customers, using the exact same versions you are dealing with.
In the past year, we have done this quite a bit and have had good success.
Make sure you pay attention to dial plan overlaps and Regions/CODECs and you
should be good to go.
HTH.
Bill
On 9/1/10 4:18 PM, "nelson.chu"
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Nelson,
HTH.
Bill
306
