01-15-2012 07:57 PM - edited 03-16-2019 09:00 AM
Anyone know what services are used for the intercluster trunk? I am decommisioning some older CallManagers in our system and thought it would be a safer option to stop the services than remove them all together. After they have been stopped we can then tell if they still being used
Cheers
Solved! Go to Solution.
01-15-2012 09:21 PM
An ICT uses the ccm service, if you stop that, it's pretty much the same as removing the server (unless it's a standlone TFTP or MOH/media server)
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
01-16-2012 06:54 AM
As Java says there is really no specific service that only controls the ICT, so your safest bet is simply remove the ICT, if you want to see if there are calls traversing it use RTMT performace (appliance based CUCM) or Windows Perf Mon to monitor call activity on the trunk.
HTH,
Chris
01-15-2012 09:21 PM
java
01-16-2012 06:54 AM
HTH,
Chris
02-06-2012 08:11 PM
Thanks guys, used RTMT to monitor it and nothing was being used, just removed the ICT
