Community Member
Intercation between CUCM-GK-CME
CM-GK-CME
I have a CUCM 7.0 and GK and CME with 12.4T version.
The ICT on GK is configured in a region to talk in G729 with phones.
The dial-peer on CME for GK is without any voice-codec class.Default is G729
The gatekeeper has not any bandwidth commands
I made a call between two phones,one in CUCM site and the other one in CME sites by  GK.
From CM to CME the codec for this call is G729. I saw the codec on all places(phone registered in CUCM, phohne registered in CME, ad on GK by show active calls)
From CME to CM the codec is on both phones G729, Instead on GK is G711(128Kbits by sh gatekeeper calls)
There is not CUBE or other devices betwwen CUCM and CME excluded the GK
CME
interface loopback 0
h323-gateway voip interface
h323-gateway voip id HQ ipaddr 10.10.200.3
h323-gateway voip H323-ID CUCME
h323-gateway voip tech-prefix 090
h323-gateway voip bind srcaddr 10.10.110.3
exit
dial-peer voice 1 voip
description from/to GK
incoming called-number .
destination-pattern 2...
tech-prefix 4
session target ras
no vad
exit
GK
gatekeeper
zone local HQ cisco.com ip 10.10.200.3
no shut
exit
VIP Purple
Re: Intercation between CUCM-GK-CME
You might be running into this bug:
CSCsl74701
See the following link.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsl74701
Here are the bug details.
ARQ requests 1280 when no regions are defined to use g711
Symptom:
ARQ sent to gatekeeper requests bandwidth for a g711 call (1280) even though only g729 is configured in all of the regions.
Conditions:
In a call routed to a GK controlled ICT and all regions are configured for g729, the originating CCM requests 160 in the ARQ to the gatekeeper. When the h225 setup arrives at the terminating CCM, an ARQ is sent to the gatekeeper requesting 1280. This is because the IntraAudioRegionDefault and InterAudioRegionDefault service paramater settings are included in the calculation for the maximum bandwidth request. Callmanager default setting for IntraAudioRegionDefault is g711.
It should check region pair before applying default if there is nothing matched.
Workaround:
Set both service parameters to g729, or increase zone bandwidth setting on the gatekeeper
Status Status
Fixed
(Verified)
Severity Severity
2 - severe
Last Modified Last Modified
Any Time
Product Product
Cisco Unified Communications Manager (CallManager)
Technology Technology
1st Found-In 1st Found-in
5.0
Fixed-In Fixed-in
7.0(0.39000.56)
6.1(1.9901.76)
6.1(1.2110.1)
6.1(2.1000.13)
7.0(0.66666.1)
7.0(0.66666.2)
7.0(1.11000.2)
6.1(3.9999.1)
Hope this helps.
Brandon
Community Member
Thenka nfor the reply. I am not sure that im running on this bug. However, I will try and then let you know.
295
