Intercluster port
Could anyone please tell me the firewall access port to be open for non gatekeeper controlled intertercluster trunk for communication manager 7.0
Re: Intercluster port
Refer to this doc
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/port/7_1_2/CCM_7.1.2PortList.pdf
java
if this helps, please rate
java
www.cisco.com/go/pdi
I already referred that and I'm not able to see any port for two different call manager clusters over the WAN.
The port IS there, i already looked in the doc.
The port is no different whether you're using it across the WAN/LAN/MAN, etc
Search ICT
The doc contains ALL the ports that CUCM uses for communication between all the different servers and devices.
java
java
264
