Intercluster Trunk between Be3000 and Asterix.
Hey Guys,
Is this possible to achieve with be3k at one end ?
Varadarajan.R
I know it works between CME and asterisk (I had it working myself). I have seen people say it won't work between CUCM and asterisk, because of authentication and that you would therefore need a CUBE.  However, have a try with a CUCM SIP Trunk, and make sure on the asterisk side you allow anonymous INVITES (i am not sure about the exact wording in asterisk), basically running SIP without authentication/registration.
Please remember to rate useful posts, by clicking on the stars below.
Thanks a lot dennis.
We dont need any authentication. Just a direct trunk between be3k and asterix. so the end users can be able to call each other using this trunk. The issue is, we dont have cucm, we have a BE3k.
Varadarajan.R
Hi Varadarajan,
If you are really willing to implement it, I would recommend opening a case with the PDI Helpdesk to get a proper confirmation as it is a design question.
http://www.cisco.com/go/pdihelpdesk
Manish
HI Manish,
Yes, we do need to this at the earliest, hence my posts here. And I shall go through PDI. Thanks for the suggestion.
Varadarajan.R
340
