Intercluster trunk between CM4 and CM6
Is it possible to have an intercluster trunk between a CM4 and CM6. I have configured one but for some unknown reason whenever I phone a number destined for the other CallManager I get a fast busy about 5 secs. Any ideas?
1 REPLY
Re: Intercluster trunk between CM4 and CM6
it is possiable !
have you checked that the aproparate CSS and partions configured on the ICT, route pattrens
also do u habe regions, locations might make problems but not with ip phone to ip phone, unless there is bandwidth limitations thats why u need to make sure its ok
good luck
if helpful Rate
156
