Bronze
Intercluster trunk between CUCM 6.1 & CCM 4.1?
Is it possible to establish Inter cluster trunk between CUCM 6.1 & CCM 4.1 versions.
I have gone through documentation for 6.1 but didn't find compatibility of features with other versions.
Regards...
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Intercluster trunk between CUCM 6.1 & CCM 4.1?
Hi Ashok,
Hope all is well :)
Yes, ICT's can be configured between different versions of CCM, like in your example 4.1(x) and 6.1(x). This functionality goes back to at least CCM 3.3 that's probably why no compatibility matrix exists.
Hope this helps!
Rob
Hi Ashok,
Hope all is well :)
Hope this helps!
Rob
Bronze
Thank you, Rob. It cleared my doubt.
Regards...
-Ashok.
Hi Ashok,
You are most welcome my friend :) Glad to be of some small help.
Take care,
Rob
338
