05-01-2014 05:38 AM - edited 03-16-2019 10:38 PM
I have CUCM 9.0 in my head officed and CME 4.0 in BO. I have create the ICT from my CUCM and the call flow works fine form HO to BO.
I know CME doesnt supports Inter Cluster Trunk so I have to make the dial peer on the CME, can any one help me sharing the template how to do it ?
Solved! Go to Solution.
05-01-2014 07:12 AM
Its very simple.
dial-peer voice 1 voip
decsription inbound dial-peer for calls from cucm
incoming called number.
no vad
dtmf-relay h245-alpha
dial-peer voice 2 voip
destination-pattern xxxx (where xxxx=your cucm extension pattern)
session target ipv4: y.y.y.y (where yyyy=cucm ip address
no vad
no vad
05-01-2014 07:12 AM
Its very simple.
no vad
no vad
no vad
05-01-2014 10:45 AM
I dont understand why I have to make 2 Dial Peers.
no vad
no vad
05-01-2014 10:59 AM
05-04-2014 12:56 AM
When I am trying to put the command
Incorrect format for E.164 Number
regular expression must be of the form ^[][^0-9,A-F#*.?+%()-]*T?(\$)?$
05-04-2014 02:10 AM
Thanks it worked
05-01-2014 07:38 AM
Don't forget to add h323-gateway voip bind srcaddr <ip address> to the interface of CME.
Suresh
