intercluster trunk conference problems
Hello Guys. We are experiencing problems we are trying to stablished conference between two sites using an non-gatekeeper controlled inter cluster trunk. The call flow is as follows we start a call from SLP site to LV site the call is received at LV site, the ip phone at LV site start a conference with another ip phone in SLP, after that we notice that the new voice call starts to be degraded as well as the voice of the original ip phone that starts the first call.
Do you have any idea that can cause this behavior?
1 REPLY
Re: intercluster trunk conference problems
HW CFB? SW CFB? where is it located?? codec? do you have QoS?
java
if this helps, please rate
java
www.cisco.com/go/pdi
323
