Intercluster Trunk issues
There are three clusters here all connected via non-GK intercluster trunks on CCM 4.2(3)sr2b. Right now, Cluster 3 cannot dial Cluster 1 (busy), but Cluster 1 can dial Cluster 3. The ICT from Cluster 3 to Cluster 2 is working fine both ways. They are using the same MRGL and device pool. I have attached the ccm to this post.
I am trying to find some information about this error, but I have been unsuccessful so far. Does anyone have any ideas?
Thanks!
Re: Intercluster Trunk issues
Check the calling search space on the trunk from Cluster 3 to Cluster 1. The trunk may be in the wrong CSS.
Green
Check as mentioned above CSS for ICT, and also check the IP address for remote trunks
Make sure it contains every seingle server for remote ICT CCM in DP example
Cluster 1 ICT
ICT
Cluster 1 has 3 servers
ICT in DP is using a CCM group that contains the 3 servers
In cluster 2 ICT pointing to Cluster 1
make sure you configure all IP addresses for Cluster 1 CCM group
142
