Intercom Feature
On our old phone system we were able to set up a paging group that would allow a manager to push a button and speak through the speakerphone to all members of his paging group (one way).  I know the Intercom Feature in 7.x does not allow shared extensions, but has anyone come up with a workaround or have any suggestions on a workaround?
1 REPLY
Re: Intercom Feature
CUCM does not have paging capabilities which is what you're looking for. You need a 3rd party to do that.
There are plenty of recommendations if you search paging in NetPro.
Berbee Informacast is a very popular one.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
182
