Interdigit Timeout - CM 4.2
Hi there,
how can I change the interdigit timeout configuration in CM 4.2 ?
Thanks.
Andrei.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Interdigit Timeout - CM 4.2
Hi Andrei,
CCM Parameter (Interdigit Timeout);
Here is the method to change the "interdigit timeout";
Complete these steps to modify the settings:
Select Service > Service Parameters to go to Cisco CallManager System Parameters >Clusterwide Parameters (Device - General) from the Cisco CallManager 4.2(x) Administration page.
Select the name of your server and service from the Server and Service fields.
Select TimerT302_msec.
In the Value field, type the timeout you want to configure (specify the time in milliseconds). For example, if you want to configure 5 seconds as the interdigit timeout, type 5000.
Caution: Be careful. Do not set the interdigit timeout value too low, otherwise the user does not have enough time to enter the digits while calling.
Click Update.
Restart Cisco CallManager to implement the changes.
From this excellent doc;
Delay in Call Establishment: Configuring the Interdigit Timeout
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800dab26.shtml#solution3
Hope this helps!
Rob
1 REPLY
Hi Andrei,
Click Update.
Hope this helps!
Rob
322
