Interdigit timeout
moropodi2008
Hi i'm using the pound(#) to terminates interdigit timeout when i'm making a call but i want to terminate the interdigit timeout without the pound(#). Where can i reduce this timing, i have already reduced T302 to 3.5 seconds ( on my CCM6).Thanks.
gogasca
Level 10
Level 10
which type of calls?
PSTN calls?
mae sure there is no overlapping patterns
(i.e you dial a 7 digit number, but cucm also matches a 10 digit local number)
here is SJ we have local 7 digit calls. but also 10 digit local calling, so make sure ur dialplan is correct
Thanks, calls to mobile numbers(cell numbers), my route patterns are fine.
what happen when u dial the last digit?
gather CUCM SDI, SDL traces and paste calling, called number timestamp and will give u more details.
