Community Member
Interdigit timeout
Hi i'm using the pound(#) to terminates interdigit timeout when i'm making a call but i want to terminate the interdigit timeout without the pound(#). Where can i reduce this timing, i have already reduced T302 to 3.5 seconds ( on my CCM6).Thanks.
Green
Re: Interdigit timeout
which type of calls?
PSTN calls?
mae sure there is no overlapping patterns
(i.e you dial a 7 digit number, but cucm also matches a 10 digit local number)
here is SJ we have local 7 digit calls. but also 10 digit local calling, so make sure ur dialplan is correct
Community Member
Thanks, calls to mobile numbers(cell numbers), my route patterns are fine.
Green
what happen when u dial the last digit?
gather CUCM SDI, SDL traces and paste calling, called number timestamp and will give u more details.
482
