Interdigit Timeout
Nathan Spitzer
I have a Call Manager 8.6 system thats driving me crazy. For some reason dialing between extensions waits for the interdigit timeout and the users are complaining. I have run a "Route Plan Report" and looked in the DN's and route patterns and verified there are no collisions. In the Dialed Number Analyser it shows that it is waiting for the Interdigit timeout. How can I figure out why it is waiting for the interdigit timeout ifthe route plan report and DN's dont show any overlap?
Chris Deren
Make sure you do not have any patterns such as XXXX, etc [1-4]XXX, !, etc, etc
Chris
If you still can't find it in the GUI you can do a Dialing Forest Dump after hours. Sometimes it's easier to view that way.
https://supportforums.cisco.com/docs/DOC-23902
Jesse
If you confirm that there are no overlaping patterns present then it may be possible with the NANP pattern like 9.@ or 9.!
Can you let us know what's the called party? It that a internal or external call?
