10-13-2010 12:06 PM - edited 03-16-2019 01:19 AM
Dear Friends
I have a customer who is running CUCM 7.1(2). They had an OLD PABX which supported an intereting fetaure. Caller A can call Caller B through direct extension dialing eg . Ext. A with number 1000 can call Ext. B with number 1002 by directly dialing the digits "1002" . If the Extn. B is not available , then Extn. A can call "#1002", then the Mobile Number of Extn.B will be dialed instead of his Extn 1002. More interestingly , Caller A can use any phones in the PABX system dialing "#1002" to reach the second person .
Do anybody know , How we can configure the same fuctionality in CUCM 7.1(2). How such a pattern can be created? . Is it possible through any RP, TP or Application Dialing rules , Speed Dial fuctions or any combinations ???..
Your Support is highly appreciated ..
Best Regards
Raj
10-13-2010 12:29 PM
You could use a translation pattern for this but it's not very scalable as you would need a 1x1 ratio of translations to mobile numbers. Personally, I would probably move away from emulating this behavior. Instead, why don't you leverage the Mobility / Mobile Connect feature in CUCM? The user would dial 1000 and ring the user's desk at 1000. Based on how you set it up, you could either have the user's cell phone ring simultaneously or apply a short delay before ringing the mobile device. You also give the called party the added ability to transfer out to cell phone from desk phone or vice versa via the Mobility softkey.
Hailey
10-13-2010 12:59 PM
Thanks David
Good suggestion . I'll work on it and will let you know the feedback . Meanwhile , If anything strikes in your mind which is more inetresting , please do post the same
Many Thanks
Raj
