Community Member
Interface ETh0 is duplicate ip
When i try to install Subscriber in the cluster, i receive an error message which i attached in this email : interface eth0 is duplicate ip.
The address doesn't exist on the network. i try to install on UCS C210 M2 server with ESXi 4.1.
If you have some responses about this trouble feel free to help me.
Hall of Fame Super Silver
My expereince with seeing this is that it is pretty accurate, I suggest you look at your ARP tables on the network to find annother device with this IP.
Chris
Gold
or find a network device on this subnet with proxy arp enabled....
HTH. Barry
Community Member
I check network but i haven't something bad. No duplicate ip address in the network. But i have the same error. Do you know if my vmware layer is correctly configure ? because it's on my interface eth0 i have the error so may be the problem come in this side.
Thanks for you return
Joseph
Community Member
Hi Joseph
How you solved the issue . I am facing the same issue.
Kindly please reply
970
