interface standby on CCM
Hi all, is there a chance to configure some standby mode on two ethernet interfaces on CCM server, I mean to connect them to different switches and in case of link failure (for example because of switch failure) the standby interface would be able to retake connectivity? Thanks
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: interface standby on CCM
Hi Thomas,
Just to add a link to the good info from Chris and Jaime. CCM 4.2(1) is good;
Using the Cisco Media Convergence Server Network Teaming Driver with Operating System Version 2000.4.4
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/win_os/driver/team_244.html
Hope this helps!
Rob
Hall of Fame Super Silver
Yes, it is supported to configure NIC teaming in CallManager. What version of CM do you have?
Chris
I have 4.2(1)
just as a note this is only supported on HP servers
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Hi Thomas,
Hope this helps!
Rob
112
