Intergrating a fax machine into cisco Callmanager express
I need some help (Configuration guide)on how to integrate a fax machine onto Cisco Callmanager express 4.0 or later connected via an FXS card.
Re: Intergrating a fax machine into cisco Callmanager express
What exactly are you looking for here? Are you just trying to route specific DID's (or a single DID) to a specific FXS port?
Hi Kplunkett,
Thanks for the response. I am actually trying to route a single DID to specific FXS port which has the FAX machine connected to it.
Have any configuration guides or urls i can follow.
Hall of Fame Super Gold
dial-peer voice XXX pots
destination-pattern ZZZ <-- number a received from telco
port x/y/z
Then check you have network-clock commands set also.
Let's assume you're getting 4 digits from the carrier, and the last four of the DID number is 8878.
First ensure the voice port is configured:
voice-port 0/1/1
description Fax Machine
Then configure the routing of the DID to your fax port:
dial-peer voice 29 pots
destination-pattern 8878
port 0/1/1
forward-digits all
That should do it. Hope this helps!
Hi, watch out that if you have "forward-digits all" for a FXS port as in the example above, router will playout these digits after fax answer the calls, that may not be the desired behavior...
169
