Silver
Intermittent calls dropping, returning fast busy
I am working an issue for Intermittent calls dropping, returning fast busy.
Here is the output of the RTMT log for the issue we see.
10/28/2010 15:37:51.546 CCM|Digit analysis: match(pi="2", fqcn="5133866428", cn="6428",plv="5", pss="BlockExploitPSTN_PT:BlockNothing:Phones_PT:System_PT:HQPSTN_PT",
TodFilteredPss="BlockExploitPSTN_PT:BlockNothing:Phones_PT:System_PT:HQPSTN_
PT",
dd="913606645773",dac="0")|<CLID::StandAloneCluster><NID::192.168.26.3><CT::
2,100,39,1.25832353><IP::192.168.26.56><DEV::SEP0016478B0C8D><LVL::State
Transition><MASK::0800>
10/28/2010 15:37:51.546 CCM|Digit analysis: analysis
results|<CLID::StandAloneCluster><NID::192.168.26.3><CT::2,100,39,1.2583
results|2353
10/28/2010 15:37:51.546 CCM||PretransformCallingPartyNumber=6428
|CallingPartyNumber=513
|DialingPartition=HQPSTN_PT
|DialingPattern=9.1[2-9]XX[2-9]XXXXXX
|FullyQualifiedCalledPartyNumber=913606645773
10/28/2010 15:37:52.014 CCM|StationD: (0000034) SEP0016478B0C8D ,
star_MediaExchangeAgenaOpenLogicalChannel packetSize=20, codec=4,
ci=40794829|<CLID::StandAloneCluster><NID::192.168.26.3><CT::2,100,16,129626
.2><IP::192.168.26.254><DEV::Port 26285><LVL::Detailed><MASK::0020>
StopTone.|<CLID::StandAloneCluster><NID::192.168.26.3><CT::2,100,16,129626.2
><IP::192.168.26.254><DEV::Port 26285><LVL::State
>Transition><MASK::0020>
10/28/2010 15:37:52.014 CCM|StationD::star_StationOutputOpenReceiveChannel
myCi=40794829
keylen=0|<CLID::StandAloneCluster><NID::192.168.26.3><CT::2,100,16,129626.2>
<IP::192.168.26.254><DEV::Port 26285><LVL::Detailed><MASK::0800>
10/28/2010 15:37:52.014 CCM|StationD: (0000034) OpenReceiveChannel
conferenceID=40794829 passThruPartyID=34135337 millisecondPacketSize=20
compressionType=4(Media_Payload_G711Ulaw64k) RFC2833PayloadType=0 qualifierIn=? sourceIpAddr=IpAddr.type:0 ipAddr:0xc0a81a02000000000000000000000000(192.168.26.2). myIP: IpAddr.type:0
ipv4Addr:0xc0a81a38(192.168.26.56)
|<CLID::StandAloneCluster><NID::192.168.26.3><CT::2,100,16,129626.2><IP:
|:192
.168.26.254><DEV::Port 26285><LVL::Significant><MASK::0020>
10/28/2010 15:38:33.996 CCM|TranslateAndTransport(129626)::wait_SdlCloseInd
- ERROR: H245 signaling connection aborted!!!|
117380916| 2010/10/28 15:38:33.996| 002| SdlSig | TtFailure
| h245CloseSessionRequest_wait_for_LcseReleaseConfirm|
H245SessionManager(2,100,23,129626)| TranslateAndTransport(2,100,16,129626)|
(2,100,39,1).25832393-(SEP0016478B0C8D:192.168.26.56)| [R:NP - HP: 0, NP: 0,
LP: 0, VLP: 0, LZP: 0 DBP: 0]
10/28/2010 15:38:33.998 CCM|StationD: (0000034)
StopTone.|<CLID::StandAloneCluster><NID::192.168.26.3><CT::2,100,39,1.258323
93><IP::192.168.26.56><DEV::SEP0016478B0C8D><LVL::State
10/28/2010 15:38:33.998 CCM|StationD: (0000034) StartTone
tone=37(ReorderTone),
direction=0.|<CLID::StandAloneCluster><NID::192.168.26.3><CT::2,100,39,1.258
32393><IP::192.168.26.56><DEV::SEP0016478B0C8D><LVL::State
10/28/2010 15:38:33.999 CCM|StationD: (0000034) SelectSoftKeys instance=1
reference=40794829 softKeySetIndex=8
validKeyMask=fffffffb.|<CLID::StandAloneCluster><NID::192.168.26.3><CT::2,10
0,39,1.25832393><IP::192.168.26.56><DEV::SEP0016478B0C8D><LVL::State
10/28/2010 15:38:33.999 CCM|StationD: (0000034) DEBUG-
star_DSetCallState(11) State of cdpc(265108) is
6.|<CLID::StandAloneCluster><NID::192.168.26.3><CT::2,100,39,1.25832393><IP:
:192.168.26.56><DEV::SEP0016478B0C8D><LVL::Detailed><MASK::0020>
You should investigate why the TCP session between the server and the gateway closed, and identify the failure on the network devices between them.
It took me some time to find out this because your CUCM version is not very specific with the messages from the logs, look at this bug to enhance the trace files
CSCsm26355
Symptom:
delayed or failed h323 call setup
Conditions:
CM sends TCP SYN to remote peer for h245 session but does not receive any response.
Workaround:
None.
Further Problem Description:
This is a request for additional debugging to make it clear when h.245 TCP session setup fails.
There are currently no intuitive SDI or alarm messages to indicate this failure. It usually requires SDL traces to identify failure to setup the TCP session.
After upgrade to fixed version the following errors appear in the CM SDI
traces:
h.245 tcp session setup failure:
TCP ERROR: H245ListenReq or H245ConnectReq failure, or received SdlCloseInd from H245Handler, Perform cleanup of H245 Session
established h.245 session experiences TCP keepalive timeout:
TranslateAndTransport(%d)::wait_SdlCloseInd - ERROR: H245 signaling connection aborted
established h.245 session receives unexpected TCP FIN or RST:
My issue is where to look.
Here is the Topology:
CUCM 7.1 --- 2960 (Pub G0/18 Sub G0/15) --- Core 3750 (G2/0/1) --- Gateway 2851
I verified on all interfaces that there are no errors.  Nothing in the logs to indicate any issues.
Any direction will be appreciated and will receive a rating.
Rick
Silver
Re: Intermittent calls dropping, returning fast busy
Hi Rick,
It would be interesting to see a debug h245 asn1 and a debug h225 asn1 from the gateway to see it's reaction.
HTH,
Art
Silver
Thanks.  I have the debugs running now and waiting for the call drop to happen again to review the logs.  I am not familair with these debugs, what should I be looking for?
Silver
H245 and H225 are protocols that work in the H.323 suite for call set
up and media.  They have disconnect cause codes similiar to Q.931 that sometimes will give you clues.
Art
Silver
Here is one of the calls that dropped.  I filtered to find the number called, my issue from here is how do I find the termination of this call in the logs from this info:
/4103266731
filtering...
            dialedDigits : "14103266731"
          activeMC FALSE
          conferenceID '00CCC5F66113B1CCF51D7D02C0A81A87'H
          conferenceGoal create : NULL
          callType pointToPoint : NULL
          sourceCallSignalAddress ipAddress :
            ip 'C0A81A03'H
            port 1720
          callIdentifier
            guid '00CCC5F66113B1CCF51D7D02C0A81A87'H
          mediaWaitForConnect FALSE
          canOverlapSend FALSE
          multipleCalls FALSE
          maintainConnection FALSE
        h245Tunneling FALSE
        nonStandardControl
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '81E40020040001030003000103'H
119207: Oct 29 14:33:05.214 EDT: H225 NONSTD INCOMING ENCODE BUFFER::= 81E400200
40001030003000103
Silver
Rick,
One of the difficulties with the two debugs is the format that they produce (as you have already experienced).  But there is very good information in there.  If you could post the section of the file just before where you found the number and then probably 200 lines below I may be able to dig something out for you.
Art
Silver
I have attached the debug output in a txt file.
Silver
Well,  we were getting somewhere, they were still in negotiation, but we had not arrived at actual media channel setup or the failure, can you give  me more?
Thanks again,
Art
Silver
hers is more
Silver
OK, What I am seeing is that the unit does open a logical channel and it
looks like #32002 (or something close - is this true?) is dialed and at that point the gateway suddenly sends a "release complete" (search on release in the debug).   This indicates to me that there is something going on at the voice port or beyond.  Can you do a debug vpm signal and post the file?
Thanks again,
Art
Silver
I am going to get the debugs you mentioned, does this go back in time or will I need to run the debug, wait for the issue to happen, then search for the issue in the log?
Silver
Hi Rick,
Unfortunately we need to have it happen again to capture the event.  Additionally please send the capture of a good call along with the details on a failed one - comparison gives us more information on your actual environemnt.  Can you also tell me what dial strings you are sending out (both successful and failed)?  Is this standard NANP, another standard E.164 country out dila, or something non-standard?
Art
Silver
i will follow up on monday.  the ckt is pri i believe but will know more then.
thank you so much for your assistance.  i appreciate it a lot
Silver
Rick,
One other thing I should have asked much earlier (thought I had) - what kind of PSTN trunk is this going out?  If it is a PRI please run a debug isdn q931 rather than the vpm.
Art
Silver
I rebooted the router Saturday night and had no report of issues until today.  The problem has resurfaced.
I have applied the debug vpm signal command and will post the results when the issue happens again.  I am looking at the log and see nothing posted outside of anything different from what was already in the log.  Should I see something different?
002912: Nov  3 11:41:38.718 EDT: %ISDN-6-DISCONNECT: Interface Serial0/1/0:2  di
sconnected from unknown , call lasted 193 seconds
002913: Nov  3 11:41:48.538 EDT: %ISDN-6-DISCONNECT: Interface Serial0/1/0:1  di
sconnected from 614xxx5000 , call lasted 81 seconds
002914: Nov  3 11:41:56.650 EDT: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  di
sconnected from 586xxx0434 , call lasted 193 seconds
002915: Nov  3 11:42:12.890 EDT: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now
connected to 818xxx7229 N/A
002916: Nov  3 11:42:19.042 EDT: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  di
sconnected from 818xxx7229 , call lasted 6 seconds
TF-CORP-VOIPGW-1#sh debug
Voice Port Module signaling debugging is on
TF-CORP-VOIPGW-1#
Silver
Ah yes,
this is definitely a PRI - please do a debug isdn q931 instead of the debug VPM (as per my earlier post).  It should give us the direction of the disconnect and the cause code which will help.
Art
Silver
Thanks.  Applied pri debug
Silver
I have 3 dropped calls from the site.
I stopped the debug and searched through the log and do not see any of the numbers listed in the log that they say were dropped.  How can I track down or debug those type of calls?
Silver
Hi Rick,
Assuming that the calls went off-site and that is the only path to the PSTN the calls should have been in the debug.  I've never experienced a debug isdn q931 not catch a call out a PRI before....
The previous VPM debug that you had before indicated they were indeed going out that PRI - not sure what to make of it.
Art
Silver
Can you also run a show controller t1 0/1/0 so we can see if there are any errors or slips?
Art
Silver
T1 0/1/0 is up.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info Firmware: 20060711, FPGA: 13, spm_count = 0
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (44 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
Do you have a firewall between the devices?
Silver
No firewall in this topology
Can you post part of the config?  I interested in the voice service voip section.
Silver
Here is the config, and I am particularly curious about one of the sections:
See above comments about the timeout after 3 seconds:
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice rtp send-recv
voice service pots
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol t38 ls-redundancy 5 hs-redundancy 2 fallback none
h323
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
  call start fast
  call preserve
voice vad-time 25000
voice translation-rule 2
rule 1 // // type any unknown plan any unknown
voice translation-profile international
translate called 2
voice-port 0/1/0:23
dial-peer voice 8000 voip
description **** SIP TRUNK TO TWTC ****
destination-pattern .T
session protocol sipv2
session target ipv4:2xx.2xx.xx.xx:4060
dtmf-relay rtp-nte digit-drop
codec g711ulaw
fax protocol pass-through g711ulaw
ip qos dscp cs5 media
ip qos dscp cs5 signaling
no vad
dial-peer voice 3099 pots
destination-pattern 999T
port 0/1/0:23
gateway
timer receive-rtp 1200
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
Ok. I just finished resolving an issue with a similiar issue and config.  If this is not an IP 2 IP gateway then you need to remove the following statement unless you have another need for them.
One other thing. What's the processor on the gateway during times of dropped calls. I suspect you'll also notice burst of high call volume in the RTMT as well.
Is this configured as a H323 gateway in Callmanager? Can you post the entire config off the gateway? What is the call volume? How many calls are active at any given time?
Silver
***RESOLVED***
the issue with this was found to be a config issue between the call manager and the gateway.  The call manager was set for fast-start and the gateway was set for slow-start.  We added more to the MTP resources and changed the gateway to reflect fast-start and the issue appears to be gone.  Why now?  There was a change, which the customer stated was not done, and there was a large increase in call volume.
Thanks all for your assistance
4800
