11-16-2009 01:25 AM - edited 03-18-2019 10:50 AM
Howdy,
I have a 2811 router with 1 primary rate and 1 fxs interface. On the fxs interface i have a fax machine. The fax call comes in over the pri and is sent to the fxs interface. Unfortunately there are a lot of failures with the inbound faxes. Even from the same numbers. About 4/10 fail.
Now when running the debug isdn q931 and voip ccapi the only thing i can see is that vad is on for the inbound fax call and as the fax is on a pots interface can this make a difference? Can i rectify by adding a generic voip interface with no vad even though this is an inbound fax and inbound dial-peer is 1 and outbound is 2?
Anything i can try to resolve?
Config:
isdn switch-type primary-net5
voice-card 0
no dspfarm
password encryption aes
voice call send-alert
voice rtp send-recv
voice service pots
voice service voip
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
isdn incoming-voice voice
isdn map address 1* plan unknown type unknown
isdn sending-complete
voice-port 0/3/0:15
voice-port 0/2/0
ring cadence pattern04
input gain -6
cptone NZ
impedance complex1
voice-port 0/2/1
cptone NZ
dial-peer voice 1 pots
description Incoming POTS Dial Peer
incoming called-number .
direct-inward-dial
port 0/3/0:15
forward-digits all
dial-peer voice 2 pots
description Branch Fax
destination-pattern 1234
port 0/2/0
11-16-2009 04:00 AM
This is a FAQ
Please configure:
network-clock-select 1 e1 0/3/0:15
And report again.
11-16-2009 10:06 AM
Yes i already have that assigned just didnt put it in the config sample.
network-clock-participate wic 3
network-clock-select 1 E1 0/3/0
02-20-2012 10:06 PM
I have come across a very similar issue. Please could you let me know how this issue got resolved.
