Intermittent one-way audio across CUBE
Currently Being Moderated
one way audio before press any buttonHi Expert and Every Member,
My UC System include  CUCM 8.6 , 1 Voice Gateway 3925 with CUBE, 300 Agent IP Phone 7942 .We can do outbound call very well. Unfortunately, when customer from PSTN do inbound call to ip phone(agents), they sometimes get one way audio call that means customer can hear ip phone's voice but Ip phones can not hear customer voice. But if customer press any button on his phone(one or few times) their are two way audio which mean is the ip phone (agent) can hear the customer voice??  This call is happen very intermittent about 10 inbound call success i get 1 one way audio inbound call. I try to do many ways to
- Check IP Routing, i can ping everything.
- All IP Phone, VoiceGateway on primary CUCM
my toplog show below:
customer phone--->pstn--->cube router----->cucm-----sccp phone 7942
voice-class codec 10
no voice-class sip outbound-proxy
dtmf-relay rtp-nte
fax protocol none
ip qos dscp cs3 signaling
no vad
dial-peer voice 32 voip
  destination-pattern 88[2-4]..
session protocol sipv2
session target ipv4:1.1.1.1
dtmf-relay rtp-nte
fax protocol none
no vad
dial-peer voice 35 voip
session target sip-server
incoming called-number .T
dtmf-relay rtp-nte
fax protocol none
no vad
!dial-peer voice 65 voip
description xxx   INBOUND
translation-profile incoming inbound
rtp payload-type nse 99
incoming called-number xx[2-4]..
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
fax protocol none
Please give me your recommends to solve it quickly please.
Thanks and best regards,
Eric
Everyone's tags (5)
1 ACCEPTED SOLUTION
Re: Intermittent one-way audio across CUBE
Can you share the cube config.
CUBE#show call leg active info
CallServiceType=Unknown
RTP Loopback Call=FALSE
RemoteIPAddress=10.74.0.31 this is a publisher ip
RemoteUDPPort=4000
RemoteSignallingIPAddress=10.74.0.31 this is publisher ip
RemoteSignallingPort=5060
RemoteMediaIPAddress=10.74.0.32 this is sub ip
RemoteMediaPort=4000
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=inband-voice what is this?
FastConnect=FALSE
my config is :
CUBE#sh run | b dial-peer
dial-peer voice 30 voip I didn't config the preferrence to CUCM dial-peer.so it will randamly choice the CUCM
destination-pattern 37[2-4]..
session target ipv4:10.74.0.32
dtmf-relay rtp-nte
fax protocol none
no vad
dial-peer voice 31 voip
session target ipv4:10.74.0.33
dtmf-relay rtp-nte
fax protocol none
no vad
session target ipv4:10.74.0.31
dtmf-relay rtp-nte
fax protocol none
no vad
dtmf-relay rtp-nte
fax protocol none
no vad
description INBOUND
incoming called-number 1234[2-4]..
dtmf-relay rtp-nte
fax protocol none
dial-peer voice 70 voip
translation-profile outgoing outbound
destination-pattern 0[2-9].......
voice-class sip profiles 1
dtmf-relay rtp-nte
fax protocol none
MPCCUBRTR01#show call active voice su
MPCCUBRTR01#show call active voice summary
Telephony call-legs: 0
SIP call-legs: 244
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 244
MPCCUBRTR01#
Plus the config, please share the output of "sh call active voice su" and indicate the calling\called number. In your CUCM what is the codec settings for the regions of CUBE/SCCP phone.
Hi Eric.
Can you try to add no vad to your dial-peer 65.
Bye
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi all,
I have show below and fund:
RemoteUDPPort=4000
RoundTripDelay=0 ms
FastConnect=FALSE
my config is :
dtmf-relay rtp-nte
fax protocol none
no vad
dtmf-relay rtp-nte
fax protocol none
no vad
dtmf-relay rtp-nte
fax protocol none
no vad
dtmf-relay rtp-nte
fax protocol none
no vad
description INBOUND
dtmf-relay rtp-nte
fax protocol none
dtmf-relay rtp-nte
fax protocol none
VIP Super Bronze
What is the IOS on your CUBE?
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please share proper full config. You are sharing part of it which isn't useful to look properly. We are interested in full config not only dial-peers.
Plus we need to know what are the codec settings on your CUCM, any MTP or XCODER configured, etc.
1844
