08-11-2012 12:20 PM - edited 03-16-2019 12:39 PM
Hey Guys,
We are experiencing intermittent one way audios. So to verifiy for evey cal show voip rtp connection was used.
By this we found all the one way audio was caused by only one IP address and the good calls have a different IP.
Has anyone experienced this, if so what was the solution.
This is the output
oIP RTP active connections OK CALL
No. CallId dstCallId LocalRTP RmtRTP LocalIP RemoteIP
1 24 23 16386 58756 192.168.2.100 91.151.8.181
VoIP RTP active connections OK CALL
1 45 44 16388 50644 192.168.2.100 91.151.2.133
VoIP RTP active connections NOK CALL
1 54 53 16396 50954 192.168.2.100 91.151.8.146
The call in red gives issues.
08-11-2012 03:41 PM
One way audio is almost always a network routing issue. The one ip involved has a routing issue with the other ip phone sub nets
08-11-2012 05:23 PM
Thanks Jeremia, do you know how I could resolve this. I have contact my SP to see if we can get that particular IP address banned or so.
