Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
internal and external calls
is there a way to differentiate between internal and external calls. e.g. can you change the ring tones?
1 REPLY
Super Bronze
Re: internal and external calls
Yes and no!
The system already differentiates - external calls should cause a 'double ring' whereas internal cause a 'single ring'.
It's harder to spot this with some custom ring tones... but you should be able to test and hear the difference between 'ring' and 'ring ring' once you know what you're listening for.
What you can't do is have completely different ring tones, unless you were to go down the complicated route of having seperate lines for internal and external calls on each phone, and setting different tones on each line. This would also require 7941 or better phones if I recall correctly.
Aaron
Please rate helpful posts.
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
171
