Internal Call Only - Cisco UC560 Phone System
I have an extension which I want to use only for internal dialing. Local dialing outside the company from this ext should not be allowed. Below is the configuration for this ext:
ephone-dn 120 dual-line
number 120 secondary 000000000 no-reg primary
pickup-group 1
label 120
description 120
name 120
call-forward noan 0 timeout 15
corlist incoming call-local
corlist outgoing call-local
I tried removing corlist incoming call-local and corlist outgoing call-local but its not working. Is there any straight forward way without creating a new cor list?
Help!
Any help??
Hall of Fame Super Gold
First of all, recomment you take it more easy, as only 3 hours have passed between your posts.
Second, as mentioned in countless posts that you can search, to block calls you can use after-hour block pattern in ephone-dn-template.
ok thank you Paolo for your comments. I will search it.
377
