internal callings it's ok, but external incoming call isn't ok
1 REPLY
VIP Super Bronze
Are you intending this call to egress the siteA gateway, cross the PSTN, and re-ingress at siteB; or, do you want this call to remain on-net?
  • If the former, what protocol is the gateway at siteA using: MGCP, SIP, or H323? Do you see the call egress this gateway as any normal off-net call would?
  • If the later, have you added a translation pattern for 813223XXXX and DDI the 813223? What does a Dialed Number Analysis show from a phone in siteA?
152
