Internal calls not completing to CCM 6 w/MGCP PRI gateway
I cut our CCME environment over to a CCM 6.0 system today, and I am having a really hard time getting inbound DID working.
The CCM is connected to the PSTN with a PRI through a 2821 MGCP gateway. Outbound calls are working fine, even passing the correct CLID digits that I programmed in the External Phone Number Mask for each DN.
The problem is, I cannot get incoming calls working at all. Whenever I call one of my DID numbers, I get a canned "You have reached a non-working number" message which I think is coming from the CO after the CCM rejects the call.
I have been going through the CUCM6 System Guide and CUCM6 Admin Guide to no avail.
How do you configure incoming DID in this type of system? Unfortunately, our DID numbers do not match any digits with their extensions, so the external phone number masks are set to the DID number. This gets passed correctly as CLID on outbound calls.
Please let me know if I haven't provided enough information. :)
Chris
Re: Internal calls not completing to CCM 6 w/MGCP PRI gateway
Here is output from 'debug idsn q931' on the gateway for a successful outbound call, and then the unsuccessful inbound call between the same two devices:
Here is the successful outbound call:
000627: Nov 3 16:45:04.586 Pacific: ISDN Se0/3/0:23 Q931: TX -> SETUP pd = 8 c
allref = 0x0002
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Net Specific Fac i = 0x00F3
Calling Party Number i = 0x0181, '2424020'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '5706441'
Plan:Unknown, Type:Unknown
000628: Nov 3 16:45:04.886 Pacific: ISDN Se0/3/0:23 Q931: RX <- CALL_PROC pd =
8 callref = 0x8002
000629: Nov 3 16:45:05.582 Pacific: ISDN Se0/3/0:23 Q931: RX <- PROGRESS pd = 8
callref = 0x8002
Progress Ind i = 0x8288 - In-band info or appropriate now available
000630: Nov 3 16:45:13.106 Pacific: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd =
8 callref = 0x0002
Cause i = 0x8090 - Normal call clearing
000631: Nov 3 16:45:13.142 Pacific: ISDN Se0/3/0:23 Q931: RX <- RELEASE pd = 8
callref = 0x8002
000632: Nov 3 16:45:13.158 Pacific: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd
= 8 callref = 0x0002
And here is the failed incoming call:
000624: Nov 3 16:44:25.986 Pacific: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8 c
allref = 0x0015
Standard = CCITT
Calling Party Number i = 0x2183, '5095706441'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '2424020'
Plan:ISDN, Type:Subscriber(local)
000625: Nov 3 16:44:25.994 Pacific: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd
= 8 callref = 0x8015
Cause i = 0x8081 - Unallocated/unassigned number
** on a completely unrelated note, it looks like I need to change the outbound B-channel allocation to bottom-up since inbound calls are using top-down.
I believe I have resolved this issue. I created a translation pattern that translates 2424020 to 200. Now internal ext. 200 rings when a call is placed to 2424040. That is exactly what I wanted.
So, is this the correct way to do DID/DOD when your DID numbers and extensions don't match digits? Use the External Phone Number mask for passing the CLID outbound and use a Translation Pattern for routing inbound calls?
Chris
This largely depends on the complexity of your dialplan and the range of incoming digits or DDI ranges on the voice port.
For example if you have only a single number incoming as you have described above, you can configure the gateway to have 0 significant digits and configure the prefix DN to be 200. You will just need to ensure that the MGCP gateway CSS can call 200.
However if you have a branch network with multiple gateways, then I would recommend being consistent and configure each branch digit transformations in the same manor.
It is not always as straight forward as in your case, and the DID will not always match your dial-plan. For example you main have several completely different numbers incoming on your gateway therefore translation patterns is the only way forward.
You need to be cautious about overlaping translations when you have multiple MGCP gateways.
It this instance, you will need to configure a different partion for each gateway and assign this to your translation pattern. Then configure a unique gateway css which includes this translation pattern partition.
This will ensure that only the incoming digits on this gateway are matched against the specific translation pattern.
For example if you have two gateways both with the same incoming number 242020, then one translation pattern can be configured to translate to 200 and another to 300. Because translation is assigned to a different partion these can be assigned to the respective gateway css.
Allan.
Please rate helpful posts.
279
